07-13-2012 06:18 AM - edited 03-17-2019 02:28 PM
First yea that it is generally good.
Got the Jabber set to connect to Presence and it worked. added connection to Call Manager and that works really well when I am in the office.
Problem: When I AnyConnect back into the network and I launch Jabber, it connects to Presence and then I see in the upper right the spinning wheel that it is trying to connect to the CallManager. It times out and the application exits completely.
I think that it should simply drop back to just Presence and IM.
The other question is why does it not connect to Call Manager?
Call Manager is 8.6.2
07-24-2012 12:47 PM
If the application exits, we'll need to look at the PRT and investigate what's going on. In Settings > Help
For the connectivity to CUCM, we may want to verify the AnyConnect is allowing that connection once connected. This can be seen in the PRT from Jabber as well.
07-26-2012 12:32 AM
Hi Richard,
Do you have the same issue with Jabber for Windows or Jabber for Mac?
Not exactly that it exits the application but not being able to connect to CUCM.
07-26-2012 05:33 AM
have not seen this behavior with my Jabber for Windows client
Do not have access to a MAC to try that.
Will turn on the debug settings and see about testing again. At the office it works just fine.
07-30-2012 02:25 AM
I experienced the same behaviour as you described and the problem was DNS - Jabber for iPad could not resolve the DNS name of CUCM.
08-05-2012 02:31 PM
Hi All
I am also experiencing these same symptoms in PoC. J4windows client ok
Have you managed to resolve the iPad DNS issue?
John Mc
08-17-2012 06:06 AM
Two potential problem areas here
1. DNS
- Can your external client get DNS?
2. Certificates (SCEP) from the FW
- Our FW guys worked through the set up with TAC
Good luck
