Jabber for iPad CUCM device name
Hello - does anybody know what the required device name syntax will be for the Jabber for iPad client?
Thanks.
Everyone's tags (5)
1 ACCEPTED SOLUTION
If you're part of the EFT you can get that information via your AM/SE. Otherwise, all that information will be provided at product FCS along with the necesary cop files for it.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
java
java
thanks yes I am part of the EFT so have asked my AM.
You shouldn't have to ask your AM.  This is not secretive information...  The correct syntax is TAB as stated in the documentation.
http://www.cisco.com/en/US/docs/voice_ip_comm/jabber/iPad/Admin_doc/output/b_Jabber_for_iPad_admin_guide_chapter_0111.html#task_84CC602B059749C1929349C97FE3052E
This link is supposed to be for the COP file but as usual, it is not the correct link.  Maybe someone can post the correct link here instead of telling us to contact the AM.
http://www.cisco.com/cisco/software/navigator.html?mdfid=280443139&flowid=29241.
Thanks I have it now but in response to your post - you do have to ask you AM if the product is in beta like it was when I posted the original question.  At that time no documentation was available.
Thanks anyway.
2024
