11-10-2014 05:15 AM - edited 03-17-2019 04:37 PM
I've had Expressway working but now calls from/to Jabber for iPhone fail with a message "Bad Extension" in Expressway-E.
Is there someone that is willing to share the search rules of Expressway-E required that are required for Jabber to make/receive calls. I think I accidentally deleted one or changed one.
Erik
Solved! Go to Solution.
11-10-2014 07:47 AM
The config for MRA only has 1 rule, it's created automatically, and it cannot even be deleted as it just proxies all call control to CUCM.
Aside from that, the only other rule you would have by default is the LocalZoneMAtch rule.
11-10-2014 07:47 AM
11-12-2014 06:27 AM
Thanks.
I've created a TAC case to get some assistance with this. Waiting for the TAC engineer ....
04-23-2015 08:16 AM
Hello
Did u ever get an answer on this..running into same issue..bad extension.
04-23-2015 08:31 AM
Yes, I got an answer from TAC and it is was the solution to my problem.
It had to do with announcing IPv6 support by the clients. (header "Requires: anat")
By creating a new Common Device Configuration that disables IPv6 (IP Addressing Mode), thus IPv4 only, and assigning this common device configuration to all devices using MRA, solved my problem.
Let me know if this also fixes your problems!
Erik Tamminga
