Community Member
jabber for IPhone issue
Cisco jabber was working well from my Iphone but after an update i can't login to cisco jabber, I tried to open it from another iphone and working.
Is there is any thing to do from my IPhone
"cannot login outside corporate network" error appears.
Community Member
Try deleting the iphone app
Try deleting the iphone app reboot phone . Reinstall app then try again.
Community Member
I did that , but not working
Community Member
Try to confirm the sip profile is using the mobile default profile on ccm
Community Member
When I changed the time for
When I changed the time for IPhone to Automatic, Jabber working
DO you know what is the reason ?
Community Member
You mentioned same login is
You mentioned same login is working on other iPhone ?
Can you specify the version of Jabber and the IOS on non-working iPhone and working iPhone ?
Community Member
165
