Community Member
jabber for iphone. registered client out of Office.
Jabber for iphone works very fine into my WLAN, but it's much helpful when the colleague are out of Office.
For example in hotel where the hotel offer the Wireless lan. Or when I use 3G network ( if I haven't an apn dedicated). Now it's possibile use the VPN into iphone, but it's more uneasy because VPN falls, when not traffic passes . What can I do? Expose the CUCM to internet( I don't believe) Have you a guide line for this situation ?
Thanks a lot.
Roberto
Blue
Are you using ASA and Cisco AnyConnect Secure Mobility Client for this deployment. If yes, eanbling Keepalives will not give this issue.
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/data_sheet_c78-527494_ps10884_Products_Data_Sheet.html
Belo FAQ has more detials
http://www.cisco.com/en/US/products/ps10884/products_qanda_item09186a0080c17004.shtml#anc5
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Community Member
Re: jabber for iphone. registered client out of Office.
Thanks for your answer. But I don't use AnyConnect, and I think that battery of iPhone with VPN always on , consumes much.
Blue
I would say go with Tested application like Cisco anyconect.
http://www.cisco.com/en/US/products/ps10884/products_user_guide_list.html
Ronak Patel
516
