Community Member
Jabber for iPhone
Hi All,
We are looking to use Jabber for iPhone. I understand that WiFi is required when users are in the office but how do iPhones connect when users are connected to 3G or public WiFi? Does a VPN need to be established from the iphone?
Everyone's tags (3)
Jabber for iPhone
Yes, review the data sheet for such info
Cisco Jabber for iPhone
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6789/ps7290/ps11156/data_sheet_c78-658146.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Community Member
Jabber for iPhone
Thanks for this.
Is this the same for the Jabba IM for iphone or can this work using ports through the firewall?
Re: Jabber for iPhone
There's separate documentation on jabber im for windows, you can find it by just searching cco exactly for that name. Requirements are discussed there.
java
798
