09-03-2015 01:04 PM - edited 03-17-2019 05:29 PM
Dear colleagues,
I´ve deployed Jabber Guest solution for a couple of customers.
One thing I could not make get working was the ad-hoc links. Whenever I try to place a call with jabber guest, I receive a 404 message unless I manually configure the link for some particular users.
Any crucial steps am I missing you may think of?
Andre
Solved! Go to Solution.
09-14-2015 02:03 PM
Off the top of my head, things to check:
09-14-2015 02:03 PM
10-08-2015 07:15 AM
Hi Mark,
Thank you for your reply.
The CSS for the trunk seems ok as long as we manually add the link for each user, pointing to ext@cucm.
But I agree with you, hopefully I can have it properly translated within the VCS server.
Andre
