Jabber guest and MRA same expressway
Hi there,
We just installed expressway E and C Ver X.8.2 for mobile and remote access Jabber Vpnless and we are planning to deploy jabber guest.
My question is as follow:
  • Can i use the same Expressway C/E for MRA and jabber guest or do i need to deploy another expressway cluster?
Thank you in advance
1 ACCEPTED SOLUTION
Hi,The Expressway does not
The Expressway does not support MRA and Jabberguest on the same server/cluster. Therefore, you'll need to deploy another expressway cluster..
Thank you Jalumbau; I really
Thank you Jalumbau; I really appreciate your help.
666
