10-29-2014 02:03 PM - last edited on 03-25-2019 08:53 PM by ciscomoderator
I am trying to develop a Jabber Guest app for a customer. I downloaded the sample xcode projects and attempted to run ABC Bank, to see how a it one would work. The build failed and I received the error: " No architectures to compile for (ONLY_ACTIVE_ARCH=YES, active arch=x86_64, VALID_ARCHS=i386). " Any help is appreciated.
I've attached a screenshot of the error message
Solved! Go to Solution.
11-10-2014 03:15 PM
From the screenshot it looks like you are using a simulator to run the sample apps. For the sample apps to work you have to build using a device. Running on a simulator is not supported.
It's on our roadmap to add support to build via simulator.
11-10-2014 03:15 PM
