Jabber Icon tray - Chats, contacts, voice messages etc
Stuart Cross
Is there a way I can remove some of the Icons on the left hand side of the Jabber window.  We are only using Jabber for phone only now and would like to remove the chat icon.  I've had a look at the jabber config file but I can't see where it can be disabled.
Jaime Valencia
AFAIK you cannot, unless you're actually using it as phone only mode.
java
if this helps, please rate
Thanks Jaime I will perhaps try that and see what happens.
I ran the following to run it in phone_only  mode
msiexec.exe /i CiscoJabberSetup.msi CLEAR=1 PRODUCT_MODE=Phone_Mode TFTP=1.2.3.4 LANGUAGE=1033 /quiet
However even though it says in the jabber-bootstrap that it is in phone_only mode I still see the chat icon as well as meetings.
Is there something i'm missing.....?
