10-26-2011 11:17 AM - edited 03-17-2019 02:11 PM
Forgive my ignorance on this one... I have the Cius and it is running very well. I keep reading about the Chat client built in and that I need a Jabber account.... Where does this account reside? How is it tied to Presence?
10-29-2011 07:19 AM
Heath,
To use Jabber client you need with CUPS or WebEx back end server. One of these apps serves as the provisioning and authoritative presence engine for the client. See the following section in the admin guide as a starting point:
http://www.cisco.com/en/US/docs/voice_ip_comm/ccmcd/admin/9_2_1/english/ciusag-usr.html#wp1134191
HTH.
Bill
12-14-2011 03:49 PM
Hi ,
I have the same problem with Heath.
I have followed document administration guide and modified the Cius configuration options pointed to Presence instead of Webex Connect, unfortunately it still cannot authenticate to the Presence server.
I saw at the troubleshooting chatpter that we should see the "DEBUG > debug apps IMPService debug".
Is there anyone knows how to access the Debug menu?
Please advise,
Heribertus
01-18-2012 09:46 AM
I was able to get the Cius Jabber client working with CUPC. This is what I did:
Example - my email might be eemge@companyabc.com. My Jabber IM client would be something like eemge@abcdef.efx.com
01-18-2012 08:26 PM
Hi eemge,
Yes, it works. I do the same things.
Heribertus
02-16-2012 10:02 AM
Eemge -
When you normally sign into CUPC do you use your full email address or just your name? shenderson@abcdef.xyz.com
for example just the shenderson or the full email address. I have tried the steps you mentioned above and the domain name in CUPS in the same as my email address so there was no difference in how I would log in...
Shawn
02-28-2012 09:23 AM
We are seeing the same issue with the Cius units we have. We are receiving "Invalid credentials" and asking to re-enter your information. However, we use the same credentials on Cisco Jabber for Windows and we are able to authenticate. We have set the Presence and Chat Server to the hostname of the CUP server and selected Cisco Unified Presence all with no joy.
Jason
02-28-2012 11:26 AM
seiferjason -
You are able to sign in using the Cisco Jabber for Windows? I havent even been able to sign in on the that..... I also pointed to Presence Server with no joy... I have a TAC case open on this and they suspect it has something to do with the fact that I use mailid when importing from LDAP...
Shawn
