Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Jabber installation error 1326
Hi, I am hitting this error installing Jabber for Windows onto a Windows 7 Enterprise PC. I have tried Jabber v11.6 and previous versions but I get the same error so it must be a local PC or permissions issue. Any thoughts on how to work around the issue?
MSI (s) (3C:94) [14:29:54:362]: Executing op: FolderCreate(Folder=C:\ProgramData\Application Data\,Foreign=0,,)
CreateFolders: Folder: C:\ProgramData\Application Data\
MSI (s) (3C:94) [14:29:54:362]: Note: 1: 1326 2: 5 3: C:\ProgramData\Application Data\
MSI (c) (38:FC) [14:29:59:657]: Doing action: setErrorUnknownError
Action 14:29:59: setErrorUnknownError.
Action start 14:29:59: setErrorUnknownError.
MSI (c) (38:FC) [14:29:59:657]: PROPERTY CHANGE: Modifying ERROR_INSTALL property. Its current value is '0'. Its new value: '4'.
Action ended 14:29:59: setErrorUnknownError. Return value 1.
Error 1326. Error getting file security: C:\ProgramData\Application Data\ GetLastError: 5
MSI (s) (3C:94) [14:29:59:657]: Product: Cisco Jabber -- Error 1326. Error getting file security: C:\ProgramData\Application Data\ GetLastError: 5
Not sure if you still have
Not sure if you still have this problem but for anyone else that does, I had to log in as the local admin and give permissions for the local "users" group to the C:\Programdata\Application Data directory.  Once I did that the install completed successfully.
I can confirm that Ken.Head
I can confirm that Ken.Head@chkd.org method worked for me.
I had same the error and after I  followed that procedure I was able to install Jabber sucesfully
Thanks Ken!
La acción se inició a las 17:04:22: setErrorUnknownError.
MSI (c) (64:BC) [17:04:22:789]: PROPERTY CHANGE: Modifying ERROR_INSTALL property. Its current value is '0'. Its new value: '4'.
La acción terminó a las 17:04:22: setErrorUnknownError. Valor devuelto: 1.
Error 1326. Error al obtener la seguridad del archivo: C:\ProgramData\Application Data\. GetLastError: 5.
MSI (s) (9C:74) [17:04:22:789]: Transforming table Error.
MSI (s) (9C:74) [17:04:22:789]: Producto: Cisco Jabber -- Error 1326. Error al obtener la seguridad del archivo: C:\ProgramData\Application Data\. GetLastError: 5.
La acción terminó a las 17:04:22: InstallFinalize. Valor devuelto: 3.
Jabber version 11.7 "CiscoJabber-Install-ffr.11-7-1"
Windows 7 Ultimate SP1 x64
569
