Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Jabber integration with UCCX v9
Hello all!
I was wondering if it is possible to integrates Jabber with UCCX v9, specifically (9.0.2.11001-24), at work we are using Jabber like an extra phone, and it works really great! But I would like to know if we can use it for UCCX instead of using hardphone and extension mobility.
Thank you!
2 ACCEPTED SOLUTIONS
Hi Ronaldo,
Yes supported
You can use jabber for windows as an agent device but only in softphone mode
Check below link
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_compatibility/matrix/crscomtx.pdf
Haitham
Not the one marked red
softphone is to use my computer for calls
Haitham
Hi Ronaldo,
Yes supported
Check below link
Haitham
Re: Jabber integration with UCCX v9
Thanks for the reply
Just to be sure, the "softphone mode" is using the option I marked, right?
Haitham
mmmmmm I dont get it, what is the difference between softphone mode and the regular one?
The chat option is disabled then?
I don't think it is related to chat
I think that when you are using softphone mode, then when you make a call, your ip phone won't reflect this except showing red light on your line button as your line is busy. and when call is answered, you will speak from your pc mic
But when using deskphone mode, and when you make a call, you will see your ip phone is calling the dialed party, when answered , you can pickup the handset to speak
you can say the softphone mode is like using ip communicator
Haitham
ip communicator also is supported as an agent phone
ooooooohhhhhhhh got it!!
Thanks for all the help Hythamhadad!!
In fact, I hate IP communicator and we are trying to move out of it.
Thanks again.
452
