Jabber Mobile Android 11.9.3 over Expressway DVO-R alternate number
D!DoubleU
Hi guys,
problems with my Jabber for Android and DVO-R.
I have CUCM 11.5 SU4 and Expressway 8.10.3 for MRA configured.
All is working also over MRA (VoIP, Chat, Video, DVO-R with the configured MobilityIdentity)
Version of Mobile Jabber is 11.9.3.257962 and Android 7.0.
If I want to use DVO-R with the option in Jabber use alternate number, I can type in the number and save.
In Jabber it looks fine, but on CUCM the MobilityIdentity is still my mobilenumber and also not a second RemoteDestination with my second phonenumber is configured.
And as a result the DVO-R dialing fails. there is a short beep on the mobile and errormessage (not valid number or busy, check number ....)
But if I configure my second number instead of my mobile as MobilityIdentity it works.
So it is not a question of rerouting css and dialplan etc..
What's wrong?
Is there a missing configpart in CUCM to accept alternate numbers for DVO-R?
Where can I check on CUCM adminpage after the alternate number in Jabberclient is setup?
Is there a second RemoteDestination?
Or is my MobilityIdentity temporary overwritten with this number?
KR
Dirk
Yes.
Configured as described in this document, step by step.
What permissions are assigned to end user
Standard CCM End User
Standard CTI Enabled
and all Standard CTI Allow "......."
