Jabber on Samsung Galaxy SII - OneWayAudio
I installed Jabber 8.6.1.842 on a Samsung Galaxy SII (model GT-I9100) (Android Version 2.3.3)
When I initiate a call from a Cisco phone (79xx) I get One-Way-Audio (audio only from the 79xx to the Samsung)
When I initiate a call from the Samsung to a 79xx phone, there is no problem
So I installed the same Jabber version on a HTC (Android version 2.2), and used the same device-id as the Samsung, connected and there
was no problem, normal two-way-audio.
Has anyone experienced the same problem?
My quick reaction is that there is an issue with this version of Jabber in combination with the Samsung Galaxy SII
I use CUCM version 8.5.1.11900-21
thx for the help in advance
Henk
  • Jabber Clients
Hi.
Same problem here.
All other features work fine (voicemail, LDAP search etc)
Tried to factory reset the phone and install Jabber only.
Tried to install the latest release of Phon firmware from Samsung, but the issue is still there.
Any point?
THX
Carlo
Please rate all helpful posts "The more you help the more you learn"
I am experiencing the same problem on Jabber 8.6.1.842 with Samsung Galaxy SII using CUCM
System version: 8.6.1.10000-15
Same problem here. I am using a Samsung Galaxy S i9000 With Android 2.3.3 with CUCM 8.5(1)SU2. I even installed the correct COP file on the CUCM, but it doesn't seem to help. I also get one-way audio when calling to/from the PSTN. The only way I get 2-way audio is when calling from Jabber to an internal extension.
If anybody has a solution, please let us know!
Hi.
In your case I think it'san android version problem. I tried Jabber on a Samsung Galaxy S I9000 with a version 2.2.1 and it worked just fine.
My I9100 has a 2.3.1 and has the above issue.
I asked Samsung support for a 2.2.1 version for my S2.
Hope this will solve this issue.
I'll keep you informed.
Carlo
@ Carlo : Please keep us posted as to the feedback from Samsung.
I however feel that I will not downgrade Android, just to support the Jabber application.
Hi All Friends,
I need some guidence regarding Jabber for Android
We are using Cisco UC520 router for VOIP, Now I want to use Cisco Jabber with UC520, We have Android Phone & we want to configure Jabber with UC520 & want to place & receive call from My android phone by UC520, I Installed Jabber on My Samsung Galaxy phone,  but I am not sure where to start, I have the TFTP server address. What do i enter in the device id field in Jabber ?
Can anyone help me
Does I need more configuration on UC520 for using Jabber ?  I have below software on Cisco UC520, Can we use CIsco Jabber on this Software,
coinop-uc520#sh telephony-service
CONFIG (Version=4.2(0))
Version 4.2(0)
Cisco Unified Communications Manager Express
coinop-uc520#sh ver
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 12.4(11)X
5, RELEASE SOFTWARE (fc1)
System image file is "flash:uc500-advipservicesk9-mz.124-11.XW5"
Hi Vikrant,
Jabber on Cisco CME/UC500 is not supported yet, see:
https://supportforums.cisco.com/thread/2090332
henk
Hi Hunk,
Thanks for responding,
I am facing almost the same issue, i have Jabber 8.6.1.842 running on Galaxy S2 2.3.4. I am actuallly unable to register the phone with our CUCM 8.5.1.10000-26, i have configured the phone as 'Cisco Dual Mode for Android' and the phone does not even register, i have nothing in CUCM logs as well. But if i configure the Phone as 'Cisco Dual Mode for iPhone' the phone is able to register (as an iphone) but then i get one-way audio intermitten.
I tested on Sony Xperia Arc as 'Cisco Dual Mode for iPhone' and it works fine!!. I am confused!!!
Any suggestions / Help?
TIA.
Mani
9175
