Jabber on Sony Xperia ZL
Hi Guys,
I'm new for this forum.
I've install Anyconnect for ICS+ then setup Jabber on Xperia ZL.
Unfortunately Jabber didn't work, it pick up the call but no sound and the call on the desk phone still ring.
I've searched some document for supported model, but anyone has any solution to make Jabber work?
Any recommend will be appreciated.
Chayanin.
Everyone's tags (3)
If you try Jabber on the same network where IM&P/CUCM and the phones are, does it work??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Re:Jabber on Sony Xperia ZL
Hi Jaime,
Actually at first time, I do use Jabber with the same network with desk phone. It didn't work. Any idea?
Thanks.
Sent from Cisco Technical Support Android App
That rules out VPN issues, so, most likely it's either a configuration issue, or if the device is not supported, that might be the issue.
java
java
I think it because of my phone. Xperia ZL is not in the list of supported device.
Just hope if someone can make it work by some "tricky" method.
Thanks for your suggestion.
hello, i use this beta
http://www.firewall.cx/downloads/doc_download/99-cisco-jabber-for-android-phones.html
work on xperia T and Z1, must be ok for ZL
861
