Jabber or Communicator
Someone please explain this to me as the documentation kinda sucks...
Am I supposed to be using Jabber or Personal Communicator to utilize my Presence server?  Jabber seems to be the up and coming but all the documents talk about communicator.
I have installed both and see that the contacts sync between each other.  I do not see anywhere where Jabber can control my 9971 phone or make calls, etc...  I do see in communicator all the options for making calls to people on my list.
So if I want to do instand messaging and video calls initiated from the PC, which do I use?
Thanks.
Everyone's tags (4)
1 ACCEPTED SOLUTION
You can use either, they both connect to CUCM and CUPS/IM&P for IM, voice and video.
Jabber does require some extra manual configuration to get all the features, CUPC got everything from the configuration on CUCM/CUPS/IM&P
Jabber is, or is going to be, the replacement for CUPC.
Either one will work, assuming you have everything properly configured.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
java
java
Alrighty, thanks.
417
