Jabber outside the Corportate Network without Expressway
angel-moon
Level 3
Level 3
All,
looking for a solution to give Jabber users connectivity when outside the corporate walls if Expressway is not an option.  The only thing I can come up with is either a VPN or have jabber point to a public IP address with some holes in the firewall to allow Jabber communication but I would prefer to stay way from punching more holes in my firewall.
Thanks in advance
All Replies Rated
Jaime Valencia
MRA is the way to go, or VPN, otherwise, you'd be better off looking at a cloud solution and not an on-prem solution.
java
if this helps, please rate
