02-04-2014 11:39 AM - edited 03-17-2019 03:55 PM
I tried searching for this answer in the community with no luck. Can the Jabber client be set to use the logged in user's credentials to log into Jabber so the user doesn't have to enter the username/password again even though it uses their same Active Directory account. And if it can, how can I automate that setting? Thanks.
02-04-2014 12:10 PM
Disregard. Found the AuthDomain string value in the HKEY_Current_User hive. Thanks.
02-04-2014 11:22 PM
hz
and now the auth is pushed through?
02-05-2014 06:43 AM
Yes. I create the required registry string values via vbs script that is run after the install of Jabber. The script is run with the logged-on user's permissions since the registry values are under the current user hive. The version of Jabber I'm using is 4.7.4.17771
02-05-2014 06:48 AM
The values I create are:
ExternalVcs
InternalVcs
Domain
Username
AuthDomain
Location is hkey_current_user/software/Cisco/jabbervideo/
