Community Member
Jabber problem
hi there,
My jabber is showing some other language and location.
when i tried to go and check in setting but i was not able to do anything there from which i can resolve my problem.
is this my windows problem or something else.
i tried to call for windows customer care but they were unable to solve this problem.
I Dont know what to do as i am not that technically good.
I tried to look solution on youtube but can find anything.
So if anyone know to whom should i contact please reply me.
2 ACCEPTED SOLUTIONS
You should reach your local
You should reach your local IT department for this so they can investigate your problem.
java
if this helps, please rate
www.cisco.com/go/pdi
VIP Red
sounds like its installed
sounds like its installed with the wrong language.
uninstall it an reinstall, choosing english as the language.
there is no option within Jabber to change the language, this is all done through the installer package
Please rate if useful
Please remember to rate useful posts, by clicking on the stars below.
java
VIP Red
Community Member
Thanks Dennisi reinstalled it
Thanks Dennis
i reinstalled it and my problem is solved
Thank you
Community Member
Re: Jabber problem
Thank you all for your valuable time to find solution for my issue. You all are very helpfull.
158
