Jabber Softphone Audio Video Calls with VDI Solution
Hello Everyone,
We have a VDI Solution based on RDP Protocol. My question is Jabber Soft Phone for Windows can make Video and Audio Calls from Clients.
Thanks and Regards,
M. Ishtiaq
Everyone's tags (1)
Hi Mohammed,
Hi Mohammed,
Jabber for windows is supported on some virtualized platforms like Citrix, thin client etc.  In virtualized environment Cisco VXME is the engine which makes it work. The VXME makes sure that the media flows local between thin clients instead of sending it to the data center together with the signalling. The signalling is sent towards the Call Manager and the VDI server in the data center.
Refer to the links below:
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/virtualization-experience-media-engine/datasheet-c78-736425.html
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/vxc/english/vxme-windows/vxme-win-105-deploy/VXME_BK_D220E5C7_00_deployment-guide-for-cisco-vxme-105/VXME_BK_D220E5C7_00_deployment-guide-for-cisco-vxme_chapter_00.html
Aseem
(Please rate if useful)
Thanks for you reply Aseem.
Thanks for you reply Aseem. As i know VMware View and Citrix are not using Microsft RDP Protocol. About Citrix I am not sure but VMware View is using PCoIP.
Thanks and Regards,
M. Ishtiaq
Yes, you are correct, VMWare
Yes, you are correct, VMWare is using PCoIP. Cisco Virtualization Experience Client 6215 does support both PCoIP and RDP.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/vxc/english/vxc_6215_1-0/9-3_rn/VXCC_BK_VCDCF31C_00_vxc-6215_rn-9-3.html
Let me know if this helps.
Aseem
Thanks Aseem,
Thanks Aseem,
We have already thin clients from Wyse. Cisco VXC 6215 is a thin client. I can't replace almost 3000 Thin Client. I Think Cisco Jabber Doesn't work with VDI Solution using RDP Protocol.
115
