You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Jabber URI dialing
can some one help me to use of URI dialing in between single cluster phones?
I have applied these steps but after that if i try to call from jabber clients no action:
Set up URI dialing
The following steps describe how to set up URI dialing in your network:
Procedure
    Step 1   Assign directory URIs to the users in your network.
    Step 2   Associate the directory URIs to directory numbers by assigning both a primary extension and phone to the users in your network.
    Step 3   Assign the default directory URI partition to an existing partition that is located in a calling search space by doing the following:
    • In Cisco Unified CM Administration, choose System > Enterprise Parameters.
    • For the Directory URI Alias Partition enterprise parameter, choose an existing partition that is in an existing calling search space.
    Step 4   Configure the SIP profiles in your network by configuring the following fields in the SIP Profile Configuration window:
    • Configure a setting for the Dial String Interpretation drop-down list box and apply the setting for all the SIP profiles in your network.
    • Check the Use Fully Qualified Domain Name in SIP Requests check box for all the SIP profiles in your network.
    Note
    At this point, intracluster URI dialing is configured. The remaining steps are used to configure intercluster URI dialing.
    Warm Regard's =========== Amit
    • Jabber Clients
    i ahve URI confiuration under
    i ahve URI confiuration under end user phone line:
    agent@cisco.com
    nut when i dial this from any jabber client seen no action.
    Have you enabled URI dialing
    Have you enabled URI dialing on Jabber via the config.xml file???
    java
    if this helps, please rate
    www.cisco.com/go/pdi
    THNAKS FOR UPDATE ME..but
    but where is required configuration for URI?
    can you help me as i am using this attached jabber-config.xml file?
    what is required to add for working URI dialing please add me in this file or if required with other steps tell me?
    would be this URI support calling from outlook contacts when select any contact?
    http://www.cisco.com/c/en/us
    http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Windows/9_7/JABW_BK_C4C679C9_00_cisco-jabber-for-windows-97/JABW_BK_C4C679C9_00_cisco-jabber-for-windows-97_chapter_0110.html#CJAB_RF_P665C309_00
    java
    this option of Directory URI
    this option of Directory URI is mentioned mail in LDAP..
    Specifies the directory attribute that holds the SIP URI for users.
    On-Premises Deployments
    Set one of the following as the value:
    • mail
    • msRTCSIP-PrimaryUserAddress
    what else is required to call URI?
    Have you tried this https:/
    Have you tried this https://supportforums.cisco.com/discussion/12130916/set-sip-uri-dialing already?
    The general config guide is at http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Windows/9_6/JABW_BK_C94DCBD1_00_server-guide/JABW_BK_C94DCBD1_00_server-guide_chapter_0111.html#CJAB_TK_E28C6E1E_00
    1658
