Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
jabber usage on iPad
Has anyone experienced a large usage of memory space using Jabber 9.6.1.171913. Over the last couple of weeks I have got a low space warning because the usage of Jabber on my ipad shows 4.7GB or higher. I have to delete the app and re-install it to resolve the issue.
I am running the latest release of IOS 7.
1 REPLY
Can you check if the detailed
Can you check if the detailed logging some how is checked or turned on; if yes you would like to uncheck it and see if that resolves the issue. Also please clarify ;
-> What generation of ipad/ ios version on it?
-> What is the version of jabber for ipad that you are using on it ?
66
