Community Member
Jabber video for iPad - no video/audio
I've got the new jabber video for iPad app and connecting it to my tms 14.1 and vcs x8.1 running TMS provisioning. I've uploaded the new provisioning template/schema to tms. I can sign in ok but when I make a call there is no audio or video. I have seen that there is already one thread regarding the same issue but it did not help me. Can anyone help me.
Rizwan
Where/who is the other
Where/who is the other endpoint you're calling??
Have you ruled out routing issues??
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
Hello Jamie,my topology is
Hello Jamie,
my topology is like
Jabber +IP Phones -->CUCM-->VCS Control with Provisioning-->VCS Expressway -->Internet -> Jabber video for IPAD.
I have tried to call from Jabber for IPAD to IP Phones and jabber for windows and vice versa and i am able to setup a call , calls are connected but there is no audio / video on both ends. I have asked network secuirty guys to check the firewall ports and they said that everything is ok on firewall. Jabber for IPAD are registered with VCS Control via proxy registeration from internent.
Rizwan
OK, so this is not as simple,
OK, so this is not as simple, as you forgot to mention this is MRA which makes a LOT of difference.
Try with another client to isolate if this is only on iPad or with any Jabber client.
But if you're able to proxy the registration and it registers fine (and shows the VCS-C IP for registration), I'd still assume that something along the lines of FW, DMZ or the NAT is the culprit.
java
158
