Jabber voice mobile issue
Hi all,
I have a jabber issue, please help me to solve it.
On left site(3xxx) is CME registed with 2811.
On right site(1xxx) is cucm,and 2851 as h323 gw connected to PSTN.
And 2851 has a AA on the gw.
There is a l2l vpn tunnel between two site.
The call between two site is perfect.
The topology see the attachment.
Once a user move form right site to left site, and his jabber voice client(1360) still registed on CUCM.
The 1xxx ext can call the jabber through the vpn. but call form pstn can't use AA to transfer 1360.
3xxx ext can't call 1360. The phone got ringing, but when user answer the call ,the call disconnect.
The caller still heard the ringback till noanswer timeout.
So does same issue when the jabber called to 3xxx.
Please give me some advice about the issue.
Hi,You have an issue after
You have an issue after signaling,
- How are you integrating your CME and CUCM?
- Which is the reason that you use AA on GW on the CUCM side?
- Is a L2L VPN Tunnel or L2L from your ISP?
Regards.
Hi Emmanuel,CUCM and CME
Hi Emmanuel,
CUCM and CME communication with h323 through the vpn tunnel.
We don't bought any auto-attent system, so we used GW AA as the best solution.
L2L VPN tunnel based on internet.
Hi zhenya5230,Can you post a
Hi zhenya5230,
Can you post a show run from your cme please? I will recommend you integrate CME and CUCM by SIP Trunk.
Regards.
Hi,here is the configuration,
here is the configuration, i del some useless configuration cause it is to long.
version 12.4
service timestamps log datetime localtime
hostname R2811
boot-start-marker
boot system flash c2800nm-ipvoicek9-mz.124-24.T8.bin
boot-end-marker
logging message-counter syslog
logging buffered 81920
no aaa new-model
clock timezone CCT 8
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.3.1 192.168.3.20
ip dhcp pool dhcp192-168-3-0
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
   option 150 ip 192.168.3.1
   dns-server 192.168.2.11
no ip domain lookup
ip multicast-routing
no ipv6 cef
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol cisco
application
 service aa flash:its-CISCO.2.0.3.0.tcl
  param operator 3209
  paramspace english index 3
  paramspace english language en
  paramspace english location flash:/
  paramspace english prefix en
  param aa-pilot 3200
archive
 log config
  hidekeys
interface FastEthernet0/0
 ip address 192.168.3.1 255.255.255.0
 duplex auto
 speed auto
 h323-gateway voip interface
interface FastEthernet0/1
 no ip address
 shutdown
 duplex full
 speed 100
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.3.254
ip http server
no ip http secure-server
ip http path flash:/gui
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
dial-peer cor custom
 name On-Net
 name Off-Net
dial-peer cor list Call-On-Net
 member On-Net
dial-peer cor list Call-Off-Net
 member Off-Net
dial-peer cor list Call-Both
 member On-Net
 member Off-Net
dial-peer voice 1 pots
 incoming called-number .
 direct-inward-dial
dial-peer voice 1000 voip
 destination-pattern 1...$
 session target ipv4:192.168.11.6
 dtmf-relay h245-alphanumeric
 codec g711ulaw
 no vad
dial-peer voice 2000 voip
 destination-pattern 2...$
 session target ipv4:192.168.11.5
 codec g711ulaw
 no vad
dial-peer voice 5000 voip
 destination-pattern 5...$
 codec g711ulaw
 no vad
dial-peer voice 5700 voip
 destination-pattern 5[789]00$
 codec g711ulaw
 no vad
dial-peer voice 3200 voip
 corlist incoming Call-On-Net
 translation-profile incoming CEO-SEC
 service aa
 destination-pattern 3200$
 session target ipv4:192.168.3.1
 incoming called-number 3200$
 codec g711ulaw
 no vad
dial-peer voice 3100 pots
 destination-pattern 31..$
 port 0/0/0
 prefix 1
dial-peer voice 3101 pots
 port 0/0/1
 prefix 1
dial-peer voice 3102 pots
 port 0/0/2
 prefix 1
dial-peer voice 3103 pots
 port 0/0/3
 prefix 1
dial-peer voice 1001 voip
 destination-pattern 1000$
 codec g711ulaw
 no vad
dial-peer voice 5500 voip
 destination-pattern 5500$
 session target ipv4:192.168.51.1
 codec g711ulaw
 no vad
telephony-service
 max-ephones 42
 max-dn 144
 ip source-address 192.168.3.1 port 2000
 auto assign 1 to 100
 service directed-pickup gpickup
 timeouts interdigit 5
 system message Campro
 cnf-file location flash:
 cnf-file perphone
 user-locale 1 U2 load CME-locale-zh_CN-Chinese-7.0.1.1.tar
 network-locale 1 U2
 load 7906 SCCP11.8-4-2S.loads
 load 7911 SCCP11.8-4-2S.loads
 load 7921 CP7921G-1.2.1
 load 7925 CP7925G-1.3.1
 load 7931 SCCP31.8-4-2S.loads
 load 7937 apps37sccp.1-2-1-0.bin
 load 7941 SCCP41.8-4-2S.loads
 load 7942 SCCP42.8-4-2S.loads
 load 7945 SCCP45.8-4-2S.loads
 load 7961 SCCP41.8-4-2S.loads
 load 7962 SCCP42.8-4-2S.loads
 load 7965 SCCP45.8-4-2S.loads
 load 7970 SCCP70.8-4-2S.loads
 load 7971 SCCP70.8-4-2S.loads
 load 7975 SCCP75.8-4-2S.loads
 time-zone 42
 time-format 24
 date-format yy-mm-dd
 max-conferences 8 gain -6
 call-forward pattern .T
 moh music-on-hold.au
 multicast moh 239.1.1.1 port 16384
 web admin system name admin password campro2811
 dn-webedit
 time-webedit
 transfer-system full-consult
 transfer-pattern .T
 secondary-dialtone 9
 fac standard
 create cnf-files version-stamp 7960 May 30 2014 10:46:42
97
