Jabber With Lenovo S880
i have a case with my LENOVO S880. OS ICS 4.0.3. I already installed Jabber Program on my Lenovo. But somehow it doesn't works and always disconnected. I also can't use this Jabber Program to make a call. Hope there is solution for this case. Thanx a bunch
Re: Jabber With Lenovo S880
I dont believe thats a supported platform. Have you reviewed the RNs to make sure it has been tested???
java
if this helps, please rate
www.cisco.com/go/pdi
This is My Lenovo S880 already installed but not function normally
The fact you can install it by no means implies that it WILL work, the BU tests the products with certain endpoints and the release notes lists such endpoints as supported, which means that it will work fine. You can try and install it on any other device which is not listed, but there's no guarantee they will work, or that they will work properly/with all features.
So, back to my question:
java
www.cisco.com/go/pdihelpdesk
java
599
