Community Member
Jabber
Hi ,
Can someone please help me with the below query.
do we need license for Jabber,if so which type (basic or enhanced)
we need jabber soft client to make and recieve internal/external calls.
our cluster: Pub,1xSub
CUCM :10.5.2
what we need is
new extension for jabber clients at cucm
jabber to make and receive calls.
Thanks in advance,
Erin
3 ACCEPTED SOLUTIONS
Silver
Hi Erin,
Hi Erin,
In 10.x, the Cisco Unified Communications Manager IM & Presence server is RTU (Right To Use) and does not require server licensing (although entitlement is achived through a valid UCSS / SNTC contract).
The actual Cisco Jabber software client can be downloaded from Cisco's website, installed and configured on a user's PC. However, the process of user configuration in Cisco Unified Communications Manager to facilitate IM & Presence capabilities for the user will consume a CUWL Standard (or possibly a CUWL Professional license) which would be managed in the Prime License Manager server.
The best place to start would be with your Cisco AM.
Ryan
Silver
Welcome! Please let me know
Welcome! Please let me know if I can offer any other help.
Ryan
= Please rate helpful posts =
Hall of Fame Super Silver
In addition to Ryan's correct
In addition to Ryan's correct response (+5), one thing to add is that if you are deploying Jabber for IM/P only you do not need any license under Jabber for everyone program. If however you need to use Jabber as softphone then you need to defined a CSF device (Jabber for windows/mac) in CUCM which will require a license. If you have CUWL licenses one CUWL license covers up to 10 devices, so a user can have desk phone + Jabber devices. UCL enhanced plus could also be an option as that supports up to 2 devices per user.
Silver
Hi Erin,
Hi Erin,
Ryan
Community Member
Thanks Ryan,
Thanks Ryan,
Silver
Ryan
Community Member
Hi Chris,
Hi Chris,
I have created CSF device(jabber) for mac.
on implementation,
able to get the ip address.
but device registration failed out.
from packet capture,found its not reaching out to  TFTP server,though tftp is mentioned in option 160.
FYI,
CUCM 10.5.2
i did not install any plugin's (COP) or any at CUCM other than creating CSF device.
please advise/direct ..
Erin
Community Member
Hi Ryan,
Hi Ryan,
on implementation,
FYI,
CUCM 10.5.2
Erin
Silver
Hi Erin,
Hi Erin,
If your Jabber client isn't able to communicate to the TFTP server I would first start by verifying that the PC (or Mac in this case) can communicate with the Unified Communications Manager and Unified Communications Manager IM & Presence server (by IP address and by DNS entry).
The Jabber client is just that, a piece of client software, riding on top of the connectivity that the underlying host (PC, Mac, Mobile Device ... etc) provides. The PC/Mac/Mobile Device must first be able to communicate to the servers (in the same fashion IP/DNS) that you would expect the Jabber client to communicate. The Jabber client doesn't nessicarily have to be on the same network as the UC servers, but does have to have two way communication (port reference guide)
Also keep in mind, if you are attempting an external connection (or a connection through a firewall) this is not natively supported without using VPN. To use VPN-less external connections you need to deploy Jabber MRA (Mobile Remote Access) using the Expressway series.
Assuming that the Jabber client host can communicate to the UC servers and you are not attempting a connect through a firewall; other areas to look at are:
  • CCMCIP Profile in the Unified Communications IM & Presence server (do you have the right TFTP servers specified and are the Presence and IM users assigned to the profile)?
  • UC Service in Unified Communications Manager IM & Presence server has all the right IP addresses/host names for the particular services?
  • Is the correct Service Profile in Unified Communications Manager IM & Presence being advertised to the user?
-Ryan
Community Member
Hi Ryan,
Hi Ryan,
Thanks for the reply.
do i need the below to be mentioned in CSF device ?,i need Jabber just to make/receive internal phone calls.Also for Presence we use Esna-Office Linx server.
150
