jpegPhoto using UDS?
I would like to clarify that when configuring UDS as the directory in jabber-config.xml it is NOT possible to use the ldap attribute jpegPhoto?  I don't store our user photos in active directory, only ldap and they aren't served via html  so before making them available via a URL I want to clarify.
Everyone's tags (2)
Super Bronze
Yes - UDS = no direct LDAP from Jabber... so no ability to retrieve the jpegPhoto att.
A fairly small number of attributes make it into the CUCM DB, and jpegPhoto isn't one.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Is it possbile to use jpegPhoto from ldap directly when configuring EDI?  All of our company user data is stored in LDAP so I'd like to pull the photos from there, not AD.
Super Bronze
What LDAP do you have, if not AD?
It should be easy enough for you to set up a test.... as long as your LDAP setup is a Jabber-supported one and the jpegPhoto attribute contains the data that Jabber expects I would imagine it would work.
Aaron
Sun Directory Server, Enterprise edition 6.3
I'll change the jabber-config.xml and see how it goes.
thanks,
-jim
I used the config generator to try and get jabber-config.xml generated correctly, here is the file I'm using:
presence
x.x.x.x
389
x.x.x.x
389
jrippas
test
jpegPhoto
uid
(&(objectClass=mcmperson)
Here is the debug from my LDAP server:
[09/Jul/2012:13:44:24 -0400] conn=384690 op=-1 msgId=-1 - fd=169 slot=169 LDAP connection from jabber_client:3203 to ip_of_ldap_server
why is it looking for capabilities if I've defined them in config file?
[09/Jul/2012:13:44:24 -0400] conn=384690 op=0 msgId=1 - SRCH base="" scope=0 filter="(objectClass=*)" attrs="supportedcapabilities"
[09/Jul/2012:13:44:24 -0400] conn=384690 op=0 msgId=1 - RESULT err=0 tag=101 nentries=1 etime=0
Not using the objectClass defined in jabber-config.xml
[09/Jul/2012:13:44:24 -0400] conn=384690 op=1 msgId=2 - SRCH base="" scope=0 filter="(objectClass=*)" attrs="supportedSASLMechanisms"
[09/Jul/2012:13:44:24 -0400] conn=384690 op=1 msgId=2 - RESULT err=0 tag=101 nentries=1 etime=0
[09/Jul/2012:13:44:24 -0400] conn=384690 op=2 msgId=3 - BIND dn="" method=sasl version=3 mech=GSSAPI
[09/Jul/2012:13:44:24 -0400] conn=384690 op=2 msgId=3 - RESULT err=49 tag=97 nentries=0 etime=0
[09/Jul/2012:13:44:24 -0400] conn=384690 op=3 msgId=4 - UNBIND
[09/Jul/2012:13:44:24 -0400] conn=384690 op=3 msgId=-1 - closing from jabber_client:3203 - U1 - Connection closed by unbind client -
[09/Jul/2012:13:44:25 -0400] conn=384690 op=-1 msgId=-1 - closed.
Any help appreciated
519
