Max Contacts in Jabber
Is there a maximum amount of contacts Jabber can hold.  We have a person here that has alot of people in his outlook contacts list, and some are not showing up in the search function in Jabber.  9.2.6 Jabber is installed.
If there is no limit what else could we look at to find out why some contacts dont appear.
Alot of the contacts are not local people in the firm, just regular contacts in outlook.
Dre
  • Jabber Clients
300 contacts is the maximum
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
This limit is the same for
This limit is the same for Cisco Jabber 9.7.2?
Eihter on IM and Presence and in Clound Deployments?
Leonardo Santana
VIP Super Bronze
Jamie-
Just to verify, you're referencing a client-side limit of the Outlook integration and not the server-side contact list membership limit, correct? I wasn't aware the former had a limit, only the later.
Please remember to rate helpful responses and identify helpful or
761
