12-20-2016 06:21 AM - edited 03-17-2019 06:34 PM
File transfer failing to upload .
Tried in Internal network it is working fine ,Maybe one client is using 10.5 it may be using peer to peer.
Please guide me to how to troubleshoot the issue.
error:File upload failed.
Chat is working fine.
Database is reachable and no errors.
External File Server is also reachable.
CUCM 10.5
12-21-2016 10:26 PM
Please be advised that presentation or file sharing is not supported on Jabber client connected over MRA. Please see the guide in the link below:
page 38.
12-22-2016 05:33 AM
It says it is supported for IM and Presence 10.5.2 and later.
Kindly cross check.
12-22-2016 05:39 AM
I get this update from Cisco TAC but I have no idea maybe you can open case referring this information.
12-23-2016 01:31 AM
I got the fix.
We need to add an url to the Expressway C http whitelist.
12-23-2016 01:33 AM
What for white list ? CUCM or IM&P
Can you able to file sharing now via MRA
12-23-2016 01:36 AM
Add a URL to my Expressway-C http whitelist to allow MFT externally. Allowed methods: POST.
"https://cup.domain:7336/files"
Yes i can do.It is working fine now.
12-26-2016 10:08 PM
Why do you add below url using 7336 ?
My CUP server already added on the whitelist with auto configured as below
Do I need to add it again seperately ?
Success: Saved |
12-26-2016 10:48 PM
1.If your deployment is MRA and you are using MFT .
2.If you can share file from internal jabber client and external jabber client can succesfully download this file .
You can see event logs in Expressway C .
Access Denied Reason : No match in http allow list.
If you cant send file from an internal client there is some other issue you are facing.
Yes you need to allow this url in editable http whitelist with FQDN of Presence as i mentioned in previous comment.
12-28-2016 10:59 AM
I faced this issue 2 weeks back when I upgraded the expressway server from 8.7.2 to 8.9 version.
MFT was working fine when before the upgrade without adding the whitelist.
I think Cisco need to update the document or it's bug they need to realize as this is not mentioned in any expressway document.
Raaj
01-18-2017 06:31 AM
Yes.Hope your issue got fixed.
01-19-2017 10:43 PM
Im trying to deploy MRA using with Expressway 8.9 and CUCM/IM&P 10.5.2
Everything works fine but desktop sharing does not via MRA .
I also configure BFCP related sip trunk and ucsf device profile.
