Mobile Remote Access Expressway - LERR_EDGE_INTERNAL_ERROR
Hi guys,
I'm deploying Jabber MRA but when I try to login externally I get this error:
[IMPStackCap::Login::OnLoginError] - ****************************************************************
2014-05-13 09:52:40,199 INFO  [0x000010c4] [ts\adapters\imp\components\Login.cpp(91)] [imp.service] [IMPStackCap::Login::OnLoginError] - OnLoginError: (data=0) LERR_EDGE_INTERNAL_ERROR <26>:
2014-05-13 09:52:40,199 INFO  [0x000010c4] [ts\adapters\imp\components\Login.cpp(92)] [imp.service] [IMPStackCap::Login::OnLoginError] - ****************************************************************
Everything seems fine on the VCS-E and VCS-C, no errors, traversal zone is up, UC services is Active.
Internally it works perfectly but externally the Jabber client prompts the message “cannot communicate with the server” and if I put the wrong password the system prompts “Your username or password is not correct”.
VCS Version is 8.1.1
CUCM: 9.1.2
CUP: 9.1.1
Any ideas?
1 REPLY
Hi,Try the
Try the following
Expressway C, under Configuration -> Unified Communications -> IM and Presence servers
Select your IM&P server and click on Refresh Server.
If you have done some changes, services restart or even nothing it could be the solution.
JC
247
