Movi Jabber Installation
Hi all,
I want to test the new Movi Jabber in my machine with Windows7. Everything is ok during the installation, the problem start when I try to launch the client, the application show me an error message about the video drivers. the error message is: "New features in this version of Movi are not supported by your computer's graphics driver. Update to the newest graphics driver available and run Movi again." then show me another message: "supportabilitytest.exe has stopped working".
To fix this, I run the "windows update" and I can not found any new driver for my notebook (HP Pavilion dv4 Intel(R) Core(TM) i3).
Anybody can help me to fix this??
Thank you in advance.
Juan
Everyone's tags (4)
Friend,
Go to HP support website and try to find there the latest driver version to your graphic card.
Paulo Souza
Paulo Souza Was my response helpful? Please rate useful replies and remember to mark any solved questions as "answered".
Paulo,
Thank you for your answer, but I did it and HP doesn't have a new one... In fact I went to Intel web site to check too, but all the driver found doesn't run in my machine...
Thank you again
Juan
Friend,
Do you have OpenGL version 1.2 or higher installed on your computer?
If you have it already installed, so I suggest you to install another version of Cisco Movi, maybe previous version of the software, because from 4.2 to 4.3 many things have changed.
Paulo Souza
Paulo,
I want to test the new version, in fact, I'm using the version 4.2 now without problem.
Thank you
Juan
What kind of grapchis card you have. What kind of direct x supportability for the card?
Alok
Alok,
Here is a brief of the information.
System Information
Time of this report: 2/23/2012, 15:16:55
       Machine name: ARG-GRANATA-L
   Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110622-1506)
           Language: English (Regional Setting: English)
System Manufacturer: Hewlett-Packard
       System Model: HP Pavilion dv4 Notebook PC
               BIOS: Default System BIOS
          Processor: Intel(R) Core(TM) i3 CPU       M 330  @ 2.13GHz (4 CPUs), ~2.1GHz
             Memory: 4096MB RAM
Available OS Memory: 3894MB RAM
          Page File: 2636MB used, 7906MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.01.7601.17514 64bit Unicode
Display Devices
          Card name: Intel(R) Graphics Media Accelerator HD
       Manufacturer: Intel Corporation
          Chip type: Intel(R) Graphics Media Accelerator HD (Core i3)
           DAC type: Internal
         Device Key: Enum\PCI\VEN_8086&DEV_0046&SUBSYS_140A103C&REV_02
     Display Memory: 1696 MB
   Dedicated Memory: 64 MB
      Shared Memory: 1632 MB
       Current Mode: 1280 x 800 (32 bit) (60Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: unknown
         Monitor Id: SEC5142
        Native Mode: 1280 x 800(p) (59.994Hz)
        Output Type: Internal
        Driver Name: igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32
Driver File Version: 8.15.0010.1986 (English)
     Driver Version: 8.15.10.1986
        DDI Version: 10
       Driver Model: WDDM 1.1
  Driver Attributes: Final Retail
   Driver Date/Size: 10/30/2009 16:23:10, 5956608 bytes
        WHQL Logo'd: n/a
    WHQL Date Stamp: n/a
  Device Identifier: {D7B78E66-4306-11CF-4E74-0034A2C2C535}
          Vendor ID: 0x8086
          Device ID: 0x0046
          SubSys ID: 0x140A103C
        Revision ID: 0x0002
Driver Strong Name: oem1.inf:Intel.Mfg.NTamd64:iILKM0:8.15.10.1986:pci\ven_8086&dev_0046&subsys_140a103c
Thank you in advance for your help.
Juan
I've got exactly the same issue. Are there any system requirements a PC has to fulfill for release 4.3? Haven't found any within the release notes.
It's a pitty that the error message is so inexpressively. Are there at least any log files / debug files that can be checked?
We've gone through this entire ordeal for the past few weeks in preparation for an enterprise-wide deployment.
Requirements for Movi 4.2 and Jabber 4.3 are almost identical.  I opened a TAC case and was told this is being seen by Cisco with users of some HPs, Fujitsus, and a few other devices.  The framework has changed a bit between 4.2 and 4.3, but they're virtually the same software.  Cisco has not come out and said there's an official issue yet.
Just FYI, for any Intel HD Graphics card, look at the driver version.  In your info above, yours shows:
Our testing has shown the build of the driver file for Intel HD Graphics has to be a minimum build of 2279.  The other numbers in the version # mean other things (i.e. "8" is Win7, "15" is the version of DirectX I think, etc.  For this purpose, we're mainly worried about the last 4 digits and of course that they're compatible with your OS.).
What we've had to do on machines in our environment is uninstall the drivers but check the box that says to delete the driver files.  Once that process is complete, see if you can do another Windows Update.  If the drivers that are downloaded aren't any better, or aren't a better build than 8.15.10.2279, you will have to manually download compatible drivers from Intel's site.
Good luck!
I've got the same issue.  I'm on a Lenovo T410S with an Intel Graphics HD (Core i5), version 6.14.10.5200 and just went through Intel's automatic update process.  I still am getting the same error.
Intel® Graphics Media Accelerator HD (Core i5)
Report Date:            4/12/2012
Report Time[hr:mm:ss]:        11:41:24
Driver Version:            6.14.10.5200
Operating System:        Windows XP Professional Service Pack 3(5.1.2600)
Default Language:        English (United States)
DirectX* Version:        9.0
Physical Memory:        2995 MB
Minimum Graphics Memory:    32 MB
Maximum Graphics Memory:    128 MB
Graphics Memory in Use:        39 MB
Processor:            x86 Family 6 Model 37 Stepping 5
Processor Speed:        2394 MHz
Vendor ID:            8086
Device ID:            0046
Device Revision:        02
*   Accelerator Information   *
Accelerator in Use:        Intel(R) Graphics Media Accelerator HD
Video BIOS:            2026.1
Current Graphics Mode:        1440 by 900
*   Devices Connected to the Graphics Accelerator   *
Active Monitors: 1
Active Notebook Displays: 1
    *    Monitor    *
Monitor Name:            Plug and Play Monitor
Display Type:            Analog
Gamma Value:            2.2
DDC2 Protocol:            Supported
Maximum Image Size:
Horizontal:            20.08 inches
Vertical:            11.42 inches
Monitor Supported Modes:
640 by 480 (67 Hz)
640 by 480 (75 Hz)
640 by 480 (72 Hz)
640 by 480 (60 Hz)
720 by 400 (70 Hz)
800 by 600 (72 Hz)
800 by 600 (75 Hz)
800 by 600 (56 Hz)
800 by 600 (60 Hz)
832 by 624 (75 Hz)
1024 by 768 (75 Hz)
1024 by 768 (70 Hz)
1024 by 768 (60 Hz)
1152 by 864 (75 Hz)
1152 by 870 (75 Hz)
1280 by 800 (60 Hz)
1280 by 1024 (60 Hz)
1280 by 1024 (75 Hz)
1280 by 720 (60 Hz)
1280 by 960 (60 Hz)
1920 by 1080 (60 Hz)
Display Power Management Support:
Standby Mode:            Not Supported
Suspend Mode:            Not Supported
Active Off Mode:        Supported
Raw EDID:
00 FF FF FF FF FF FF 00 04 72 A6 01 16 02 01 14
28 15 01 03 68 33 1D 78 2E 77 C5 A5 57 52 9C 25
11 50 54 BF EF 80 81 C0 81 40 71 4F 81 80 81 00
D1 C0 01 01 01 01 02 3A 80 18 71 38 2D 40 58 2C
45 00 FE 1F 11 00 00 1E 00 00 00 FD 00 37 4B 1E
50 10 00 0A 20 20 20 20 20 20 00 00 00 FF 00 4C
4E 5A 30 38 30 32 31 34 32 30 34 0A 00 00 00 FC
00 41 63 65 72 20 53 32 33 31 48 4C 0A 20 00 50
    *    Built-in Display    *
Monitor Name:            ThinkPad Display 1440x900
Display Type:            Digital
Gamma Value:            2.2
Maximum Image Size:
Horizontal:            11.81 inches
Vertical:            07.48 inches
1440 by 900 (50 Hz)
1440 by 900 (60 Hz)
Standby Mode:            Supported
Suspend Mode:            Supported
Raw EDID:
00 FF FF FF FF FF FF 00 30 AE 36 40 00 00 00 00
00 12 01 03 80 1E 13 78 EA E5 95 93 56 4F 90 28
28 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 C1 29 A0 E4 51 84 1A 30 30 20
36 00 2F BE 10 00 00 19 DE 22 A0 2C 51 84 7E 30
30 20 36 00 2F BE 10 00 00 19 00 00 00 0F 00 95
0A 32 95 0A 28 1E 09 00 4C A3 42 54 00 00 00 FE
00 4C 54 4E 31 34 31 42 54 30 38 30 30 31 00 CB
* Other names and brands are the property of their respective owners. *
Finally I have it running on my Lenovo W500. It's a question off the chipset which is in use, controlled through the BIOS settings. The W500 notebook comes with two grafic card chipsets on board. The "ATI Mobility FireGL V5700" and the "Mobile Intel(R) 4 Series Express Chipset Family" for power saving. If I configure my BIOS to use only the Intel card it doesn't work. If I configure it to go for the ATI chipset it works fine.
I guess that the Intel Chipset misses the required features for Movi, but the ATI has it all. Change the BIOS, update the drivers of the other grafic card and it should work.
4077
