MRA jabber login problem with CUCM Ldap
I can login with local user on outside of the branch, but I could not login with LDAP user. I saw “user and password error” on jabber for iphone’s screen. By the way I can login with jabber for windows on local network. Error event logs are on attachment,
Murat
Is it only Jabber for iPhone
Is it only Jabber for iPhone having the issue or do you have the same problem with Jabber for Windows when trying from externally?
Is there any difference in the "End User" settings between the local user and the LDAP synced user? Is the Home Cluster ticked on the End User profile as well as the IM checkbox below that?
It is the same with jabber
It is the same with jabber for windows. No, there is no dinfference. Sure, Home cluster ticked on the end user
How many CUCM clusters do you
How many CUCM clusters do you have, is there only one or more. If there is more then are they synced using ILS?
Can your VCS access/ping via IP,name and FQDN?
Looks like home cluster for TC800144 is poiting to  ktlmsubb2 (screenshots are not very clear). But VCS seems to be having issues with accessing it via hostanme.
Leszek
We have pub and 3 sub. Yes, I can access via IP, name and FQDN,
Murat
How did you verify this
How did you verify this connectivity, from VCS?
Leszek
with traversal zone, and it
with traversal zone, and it is active now
152
