Community Member
One way audio or Video in Jabber guest
I am getting issue in one way audio or video
in my deployement
jabber guest client --------- cisco expressway-e--------cisco expresway c and jabber guest server
when i am calling from jabber guest client , audio or video is not working from inside to jabber guest client
and i am not able to see any logs in expressway-e only call detail coming on expressway C
in expressway c-log media routed is false.
i opend all the ports in my firewall any any is there but still not working.
Hi Sushant,Please check the
Hi Sushant,
Please check the following two links for some good pointers
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Guest/10_0/rn/JABC_BK_C008FA26_00_cisco-jabberc-server-100-release/JABC_BK_C008FA26_00_cisco-jabberc-server-100-release_chapter_010.html#JABC_TP_A9E9E489_00
https://supportforums.cisco.com/discussion/12275221/no-videoaudio-jabber-guest
Manish
Community Member
Hi All, Issue is resolved now
Hi All,
Issue is resolved now i on ISE in unifiied communication zone and in jabber guest server
redirected to TURN server (Expresway-E)
Community Member
what do you mean by ISE? im
what do you mean by ISE? im having exact same problem with one way audio and video. Media is working from external to internal network only.
Community Member
Hi Uldis , First check these
Hi Uldis ,
First check these settings in Jabber guest serve site .
these settings for Dual Nic Deployement
SIP PORT = 5061 or 5060 (Depend what u r using TLS or TCP)
SIP Domain
SIP Server == expressway-e  FQDN
check expressway-c server that provide TURN Service
Expressway-C server FQDN
Check box Expressway-C server that proxied the HTTP request from Jabber Guest client
HTTPS Port 443
Expressway-TURN FQDN = Expressway E FQDN
Static nat mode select
public ip  >> External IP >>> INternal IP
Make sure 3478 is opend from Outside to inside or vice-versa
And make a neighbour zone between both server expressway-e to Jabber guest and Expressway C to jabber guest.
It will work
there is no use of ICE it was in my last post becuase i was also doing first deployement .
532
