Community Member
Photo mismatch in jabber for android 9.6
Hi All,
I'm having issues with the cisco jabber client on the android 9.6:
1- The contact photos not all of them displayed correctly. there are some people having wrong photo displayed for them. but, when I click on that photo, its fixed  !! why is that !! only in the android version, the windows version is fine 100%.
2- how can I stop the sync feature for the contact with the phone contact ?? I don't want the jabber contact to be shown in my android mobile contact, and to conflict with my original contact. can I do that ?
Thanks alot
Everyone's tags (1)
Community Member
1.  I think this plagues
1.  I think this plagues other jabber clients (windows/ios) too...  This is an internal bug.
2.  If I'm not mistaken, you have to update your field mappings in CM:
     CM > Application > Legacy Client > Settings > clear Photo field
Give that a try...
Community Member
Hi All bro, al.ibrahim.14,
Hi All
in the jabber client for windows 9.7  works fine, but i cant still see the photos in jabber client for android 9.6
help me please
The jabber for android works
The jabber for android works on Jabber-config.xml now to fetch contact resolution and contact photo retrieval; please refer to the following doc to learn more about it;
Do you have thumbnail photo
Do you have thumbnail photo configured for Jabber for Android; if "YES", then here is the defect that you are running into;
Please wait on the next release of the jabber for android and refer to the release notes for the bug fix.
Please rate if this helps.
