08-04-2014 05:31 AM - edited 03-17-2019 04:22 PM
Which ports are used between Cisco Expressway-C and Cisco Jabber Guest server?
Solved! Go to Solution.
08-07-2014 09:54 AM
OK, I understand. We will look into adding this information to our documentation.
Mike
08-12-2014 02:29 PM
Hello Anton,
The Ports and Protocols section of the Installation and Configuration Guide has been updated with the ports used between Cisco Expressway-C and the Jabber Guest server:
Justine
08-05-2014 03:47 PM
Hi there,
Please see this section of Jabber Guest documentation for more information on ports and protocols used in the solution. Does this answer your question?
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Guest/10_0/icg/JABC_BK_J0FC634A_00_jabberc-installation-and-configuration-guide/JABC_BK_J0FC634A_00_jabberc-installation-and-configuration-guide_chapter_010.html#JABC_RF_P51279BF_00
08-06-2014 01:46 AM
mrmccann, thank you for your answer.
I have not found which ports we need to open between Expressway-C and Jabber Guest based on this document.
Will be i right if i say that we need open this ports: 5060/5061 for SIP and 8443 for HTTPS?
08-06-2014 09:51 AM
Our typical deployments don't have a firewall separating the Expressway-C and Jabber Guest server, so I'm confused as to why you need to "open" ports between these servers?
You are correct that SIP and HTTPs are the communication protocols between the Expressway-C and Jabber Guest, so those would be the ports these servers would be communicating on.
Can you explain more about the need for this information, so I can ensure our documentation covers it appropriately?
Mike
08-07-2014 06:19 AM
Information about ports is requested by Security Deparment. Without this information Jabber Guest deployment can be forbidden.
08-07-2014 09:54 AM
Mike
08-11-2014 06:33 AM
Thank you.
08-12-2014 02:29 PM
Hello Anton,
Justine
