protocol handlers not registered
JFW
In some cases the protocol handlers will not be registered...we did multiple installations...no success...we tried to post register some dlls...no success...
Appreciate any hint
Andreas
a little more....
Analyzed the logs a little deeper there is a difference between working and non working installations...some error conditions occurring:
INFO  protocol handlers not registered protocol handlers not registered protocol handlers not registered protocol handlers not registered - Setting registry settings
2012-06-05 09:36:02,897 ERROR protocol handlers not registered protocol handlers not registered protocol handlers not registered protocol handlers not registered - Failed to create Software\Policies\Microsoft\Office\14.0\Common\PersonaMenu in 80000001 use64Bit: 0
2012-06-05 09:36:02,897 ERROR protocol handlers not registered protocol handlers not registered protocol handlers not registered protocol handlers not registered - Failed to create SOFTWARE\Microsoft\Office\Outlook\Call Integration in 80000002 use64Bit: 0
2012-06-05 09:36:02,897 ERROR protocol handlers not registered protocol handlers not registered protocol handlers not registered protocol handlers not registered - Failed to create CLSID\{8885370D-B33E-44B7-875D-28E403CF9270}\TreatAs in 80000000 use64Bit: 0
How to avoid this?
Andreas
1 REPLY
It seems like it's having trouble talking to the registry; perhaps the user authenticated to Windows doesn't have permissions?
You could check to see if you have access to these Windows Registry keys:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Outlook\Call Integration
HKEY_CLASSES_ROOT\CLSID\{8885370D-B33E-44B7-875D-28E403CF9270}
HKEY_CURRENT_USER\Software\Policies\Microsoft\Office\14.0\Common\PersonaMenu
The error message included isn't really that useful.  Maybe if you can attach the entire logfile to this thread we can dig into it more.
467
