Question about Jabber Guest Solution
Dear All
Kindly help us ., to answer the question
- Do we able to install only one Express C or Express E for the Jabber Guest solution ? or we hvae to install the both Express C and E ?
- Does the Jabber Guest still require Presence server ?
- Do we able to use Mediasense to record the Video call of the Jabber calling session ?
- Do we still use Cisco Jabber SDK for Jabber Guest ?
Best Regards
Boonpot
Jaime Valencia
AFAIK this is still in EAP and you would need to register here:
https://communities.cisco.com/community/technology/collaboration/usergroups
Or look into the partner communities for answers to your questions.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
