report of client versions
Does anyone know of a way to generate a report/extract info from CUIMPS 9.1.1SU2 or CUCM 9.1.2 that shows the number of presence clients(cups or jabber) and their version?
Thanks!
Not apart from listing them
Not apart from listing them in the GUI (Application>Cisco Jabber>User Settings) list all then copy & paste....
I would assume there would be an SQL query to run from CLI but I am not up with the statements for CUPS.
This used to display on the
This used to display on the user search page but with IM and Presence it appears that it is gone. I used this to send a report of out of date clients to desktop support for updating.
Has this moved to another location or is there a way to bring the client version field back to this search page?
Has anyone found a workaround
Has anyone found a workaround yet? In 8.X versions you could search users in CUPS and the client version was there. Since Presence users moved to CUCM in 9.x and above I can't find a place to get version info per client except for "if" the user has a CSF device that has been registered which is not the case for all of our users.
http://docwiki.cisco.com/wiki
http://docwiki.cisco.com/wiki/CUPS/IM%26P_FAQ#Can_I_get_a_report_of_Jabber_versions_being_used.3F.3F
java
if this helps, please rate
www.cisco.com/go/pdi
Thank you Jaime.
Thank you Jaime.
I may give this a try next change control window. We have a few thousand users and I am concerned about CPU on the IM&P Pub when running the query. Hopefully Cisco will bake this into a future release as it was helpful tracking Jabber versions.
173
