Community Member
Rolling out Jabber
Hi Nerds
We are in the process of rolling out jabber for all the windows users (+- 500 Users). I am struggling to create UPC bulk profiles at once. Has anyone done this? Please give heads up. I have created individual profiles for testing and it works like a charm.
Thanks in advance...
1 REPLY
You should be creating CSF
You should be creating CSF devices if you're using Jabber, not UPC.
You can use BAT to create the devices just as with any other IP Phone.
java
if this helps, please rate
www.cisco.com/go/pdi
64
