Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
SIP configuration error
Has anyone gotten this error in Jabber Guest yet?  I've triple checked my config and can't see what the problem is.  When I click the call button I immediately get this error:
The link resulted in a server error.
Message: SIP configuration error
Category: 9 (SIP_CONFIGURATION_ERROR)
Code: 0
THanks,  Mike
Bronze
Mike,I'm sure you've seen
Mike,
I'm sure you've seen this doc, but it is worth checking out if you have not. http://www.cisco.com/c/en/us/support/docs/unified-communications/jabber-guest/118592-technote-jabber-00.html
Next, have you reviewed your chip.log on the test PC?
This smells like a possible TURN problem and the chip.log will be really helpful.
-- -Mark Turpin
Hi Mark.  Thanks for the
Hi Mark.  Thanks for the reply.  I have seen that doc.  The issue turned out to be how the "Default caller SIP alias" is entered under the Links menu.  Poor user interface here on Cisco's part.  When I read "sip alias", I think user@hostname.  But Jabber Guest is only looking for the user portion.  Entering the full alias caused all calls to fail.  In my opinion they should re-word the title of the field and provide some sort of validation to throw an error if the full uri is entered.
Bronze
Ah yes, been bit by that one
Ah yes, been bit by that one too. Glad to hear you found it!
If you have access, check out the June 24th 2015 Jabber Guest presentation on PEC. It was very helpful for me.
-- -Mark Turpin
196
