Community Member
Stop displaying Home phone number in Jabber client
Our Jabber client is pulling our data from AD.  In AD, we store the users home phone number for emergency use, but Jabber is displaying it.  Is there a way to remove or control the data that is being pulled from AD?
1 REPLY
You can change the field
You can change the field mapping in the jabber-config.xml file
java
if this helps, please rate
www.cisco.com/go/pdi
153
