08-08-2013 11:45 AM - edited 03-17-2019 03:27 PM
I have seen in documentation that Jabber for Windows 9.2.1 supports UDS via xml file configuration.
Question:
a) I have CUCM 8.6.2, Is there a way to configure Jabber for Windows with UDS for CUCM without xml customization.
b) Which other Jabber clients support UDS?
08-08-2013 01:33 PM
a) no, you need to config the .xml for UDS to work
b) AFAIK only J4W supports UDS
HTH java if this helps, please rate www.cisco.com/go/pdihelpdesk
08-08-2013 07:04 PM
Any plans in CUCM/Jabber roadmap to support a and b?
Gracias Java
