UDS Token Replacement field other than userid
Using Cisco UDS with for directory integration with CUCM/IMP and Jabber 10.5.  The jabber deployment guide says that with UDS you can use <UdsPhotoUriWithToken> for URL for photos with the %%uid%%  token replaced by userid. I would like to use a different LDAP field instead of samAccountname. Is there a way to use a different token for this replacement? If so how does this token get formatted?
Everyone's tags (1)
1 REPLY
Bronze
Hi, If your Jabber clients
If your Jabber clients are using UDS (by default they use LDAP/AD) you maybe stuck with the UID.
Using LDAP gives you a few more options with photo substitution. Search for PhotoUriSubstitutionToken' within the below link for assistance
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Windows/9_7/JABW_BK_C4C679C9_00_cisco-jabber-for-windows-97/JABW_BK_C4C679C9_00_cisco-jabber-for-windows-97_chapter_0111.html
Also check out the Jabber config generator which may help out http://cs.co/6036V7yG
98
