URI and IP-Address dialing from Phone/Jabber
we have a callmanager with a polycom videoconferencing solution.
The polycom system is attached via sip-trunk.
They have a request, where it seems that this is not configureable on callmanager.
1.) Call from phone a IP-Address with dots, for example 192.168.10.1
2.) Call from phone an URI, for example company@domain.com
We used a Routepattern 6.!, where i cut the leading number 6. The Polycom system is having rules to dial or establish this call requests.
We have the following solutions sucessfully tested (IP= 192.168.10.1):
RP= 6.!, Called= 6192168010001
RP= 6.!*!*!*!, Called= 6192*168*10*1
But how can i send dots? or a uri?
We don't support dialing IPs,
We don't support dialing IPs, and for URIs, you need to configure a sip route pattern to match the domain portion and route via a sip trunk.
java
if this helps, please rate
www.cisco.com/go/pdi
Hello Jaime,thank you for the
Hello Jaime,
thank you for the quick answer. Then my last concerns are, how to use Sip RP.
They will send it allways to the same trunk, but with diffrent uri's
How can i use the sip route pattern in a variable way?
Not sure what you mean by
Not sure what you mean by variable way.
java
Hi, i have open a Cisco TAC
i have open a Cisco TAC case and we figured out that later callmanagers have more options for this. But i have to deal with CUCM 8.6.2 and will have to implement a workaround.
For my first point i have a feature enhancment request (CSCuq09077) now:
I cannot insert a @-symbol or
I cannot insert a @-symbol or more then one dot in a routepattern, so far it is not working.
The reason could be the meaning of dot and @-symbol in a routepattern.
i know, we talk about callrouting, but he says, that a polycom is able to send uri and ip in sip-ivite to the callmanager?!
Bronze
 Hi,I have been playing
I have been playing around with Public IP Address dial with UCM 10.x and VCS the below post might be useful depending on what manipulation the Polycom environment is capable of
Post
https://supportforums.cisco.com/discussion/12263426/ip-address-dial-out-cucm
637
