uri dialing between cisco UC clusters and Lync
Is it possible to configure URI dialing between Cisco clusters and lync all in the same domain. If so at a high level how is this achieved. I know between cisco clusters the Intercluster location service in each cluster keeps a catalog of URI and sync with other UC clusters. How does link handle URI call routing with same domain?
  • Jabber Clients
1 REPLY
HiIt is possible....After you
It is possible....
After you setup the SIP URI Dialing and a SIP trunk between the CUCM and Lync, you have to configure a SIP Route pattern with the affected namespace and with the SIP trunk to Lync. You should set the URI Lookup policy (System - Enterprise Parameters) to Case Insensitive. As Directory URI I suggest to use "mail" attribute instead of "msrtcsip-primaryuseraddress".
Here you can see my earlier discussion about SIP URI dialing: https://supportforums.cisco.com/discussion/12130916/set-sip-uri-dialing
Cheers, Laci
592
