05-09-2014 12:29 PM - edited 03-17-2019 04:08 PM
Is it possible to setup collaboration edge (jabber remote access via VCSE) on a single VCS with the start pack installed? If possible, what extra license do I need because the unified communication section is not there.
Thanks.
Solved! Go to Solution.
05-10-2014 12:11 AM
I have not seen anything supporting collaboration edge architecture on VCS Starter pack
I don't see who you couldn't deploy collaboration edge in parallel with with the starter pack. The following link (session PDF) is very useful on deployment, design and part numbers.
https://www.ciscoliveaustralia.com/connect/sessionDetail.ww?SESSION_ID=1207
05-10-2014 12:11 AM
05-14-2014 10:51 AM
Thanks for the info, that was very helpful.
It looks like I will have to deploy the free version in parallel to my starter pack. How does the licensing work with the Expressway-C and Expressway-E (free version that comes with CUCM 9.1.2)? Do I need to order a zero cost line item to get these free licenses?
Thanks for the help.
05-17-2014 06:50 AM
Yes as long you have UCL or CUWL you can get them. The session PDF that was in the link also covers off the required part numbers.
