03-05-2012 03:17 PM - edited 03-17-2019 02:15 PM
03-06-2012 03:09 PM
03-05-2012 03:32 PM
Do you mean as a client so that you can use an application to make phone calls, etc?
If so checkout Cisco Jabber for iPhone.
Chris
03-06-2012 10:28 AM
Thanks Chris,
Exactly, its ipad -1 and I wanted use to make phone calls. Does iPhone and iPad support the same Cisco Jabber?
03-06-2012 12:14 PM
Correct.
HTH, please rate all useful posts!
Chris
03-06-2012 03:03 PM
Many thanks Chris,
What configuration it requires in the backend CUCM? any special config while adding phone device?
03-06-2012 03:09 PM
03-07-2012 12:27 PM
Does Cisco Jabber and cisco mobile 8.1 are the interchangeable names? on itunes if I'm looking for Cisco 8.1 it is redirecting to Cisco Jabber
03-07-2012 12:51 PM
Yes, Cisco Mobile was re-branded as jabber.
HTH,
Chris
03-07-2012 03:01 PM
Thanks Chris, great help!
