XMPP Federation with VCS/Expressway 8.1.1 in DMZ to IMP Node?
Customer is setting up a open XMPP Federation with cisco.com.  They would like to know if a more secure solution than NAT public ip to private:5269 is available.
Can we route cisco.com XMPP  traffic to VCS/Expressway 8.1.1 in DMZ and have that route to the IMP Node inside?
IMP 10.0.1SU1
Reference on XMPP Federation
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/im_presence/interdomain_federation/10_0_1/CUP0_BK_I0607EF2_00_integration-guide-interdomain-federation-100/CUP0_BK_I0607EF2_00_integration-guide-interdomain-federation-100_chapter_01010.html#CUP0_RF_D7F8598A_00
Hi Jason, This feature is not
Hi Jason,
This feature is not tested or supported at present. I'm unsure if this is in the road-map, but I will double check.
Nirmal Issac
Hi Jason,XMPP Federation on
Hi Jason,
XMPP Federation on Expressway will be available from Expressway v8.2, which is due for release. We do not have definite date on the release but should be soon
With the new version(8.2), XMPP federation can be setup directly on the Expressway
With the current release, you can setup the XMPP federation on the IM&P server and clients logging in through MRA/Expressway will be able to communicate to federated contacts and this traffic would be through Expressway
Expressway 8.2 has been
Expressway 8.2 has been published on CCO
http://software.cisco.com/download/release.html?mdfid=286255326&softwareid=280886992&release=X8.2&relind=AVAILABLE&rellifecycle=&reltype=latest
if you want to follow the instructions to federate using VCS-E go to the Admin Guide:
http://www.cisco.com/c/en/us/support/unified-communications/telepresence-video-communication-server-vcs/products-maintenance-guides-list.html
VCS/Expressway is out in
VCS/Expressway is out in version 8.2.1 with XMPP federation. Check Expressway Administrator Guide for detailed description and configuration steps.
For our deployment its working perfectly.
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/admin_guide/Cisco-Expressway-Administrator-Guide-X8-2.pdf
J.
1113
