告知
シスコ サポート コミュニティへようこそ!あなたの ご意見 をお聞かせください。
Root switch
How do configure switch as a root switch for current vlan and the future vlan in the 3560 , and what are the options are?
1 件の返信
Silver
Re: Root switch
With spanning-tree command, you can specify a switch to be (primary) root switch for one vlan or a range of vlans.
Cat3560(config)# spanning-tree vlan 100-200 root primary
An alternative way is, you can simply specify the priority to be 0 for one vlan or a range of vlans.
Cat3560(config)# spanning-tree vlan 100-200 priority 0
BTW, in case you didn't notice, you are supposed to be using Japanese in this community.Me too.
I  recommend you post to the English version of support community if your  question is in English. You may get quicker/better responses.
504
返信
